Brakes cut out yesterday. Here's the story.
Old Aug 10, 2021 | 02:11 AM
  #21
The Deputy's Avatar
Calipers are on the right sides, correct? Bleeders must be on top of caliper, if you have them wrong, right side on left side, vise-versa, bleeders will be on bottom...and you will never get air out of system.
Old Aug 10, 2021 | 02:15 AM
  #22
Brandon318's Avatar
I hope I'm not that dumb but would make sense. I'll check tomorrow.
Old Aug 10, 2021 | 04:45 PM
  #23
Brandon318's Avatar
SOLVED. Thanks @The Deputy I am indeed the idiot I was hoping I wasn't. The fronts were on right-side up, but the rears were swapped. The brakes have never felt better.
Old Aug 10, 2021 | 06:15 PM
  #24
The Deputy's Avatar
Good news!
And don't feel bad...you are not the first to experience this...and it's highly unlikely...you will be the last.
Old Aug 10, 2021 | 06:21 PM
  #25
COSPILOT's Avatar
OP and another commented on negative experiences with EBC brakes, would you both expand on that? I switched to EBC recently, only 1,000 miles on them so far, but I’m happy. Between all my Rovers I’ve had mixed results with factory rotors and pads and decided to try something different.
I couldn’t care less about looks. I care about noise, not even life of the pads/rotors.
Old Sep 18, 2021 | 04:08 PM
  #26
Brandon318's Avatar
Wanted to follow up with all this. The solution for me was replacing the pads and rotors (went OEM) and also the brake booster and master cylinder (sourced both of these from a junk yard Disco). Brakes have never felt better.
escott16
Nov 25, 2017 10:22 AM
redrover99
May 21, 2015 07:56 PM
CANAMDiscovery
Jun 4, 2012 06:54 AM
m1964
LR2
Nov 17, 2008 09:49 PM
cbrantner
Nov 7, 2007 05:33 PM
