Brakes need pumping to work
Old Dec 9, 2009 | 10:20 PM
RamblingMan's Avatar
Default Brakes need pumping to work
Hello,
I've got a 94Disco, 100k miles. The driver's side front caliper busted a seal while I was driving and I lost all braking power. There was fluid in the reservoir a tiny bit below the minimum line when I got home. So I replaced the caliper, bled the line and topped up the fluid . Now the brakes need to be pumped a couple/few times to stop the car. If I press just once, the pedal hits the firewall but there is some stopping power. The other calipers aren't leaking from what I can see.
Is this a sign of the master cylinder being dead? I did a search and couldn't find any answers so far.
Thanks,
RM
Old Dec 9, 2009 | 10:28 PM
lipadj46's Avatar
If you bled them properly then I would say master cylinder.
Old Dec 10, 2009 | 10:25 AM
How much and which DOT fluid did you use, did you rebleed the master cylinder before doing a complete 4 wheel bleed, apx 3 to 4 ints?
Old Dec 10, 2009 | 05:10 PM
Hey Mike,
No I did not rebleed the master cylinder. I didn't even know I had to do that, or how to do it. I will look up how to do it and bleed the four wheels then master.
Old Dec 10, 2009 | 06:34 PM
Buy 4 pints of DOT 4.
DadOfRoverOwner
Jan 16, 2021 07:32 PM
A5scott
Sep 9, 2011 10:35 PM
airic
Jan 18, 2009 08:07 AM
nitrocharger
Sep 21, 2008 09:08 AM
