braking system improvements?
on
1 Post
RE: braking system improvements?
Braking is good for a Disco with stock size tires, it's when bigger tires are put on and its weight is augmented by tons of add-ons that braking becomes marginal. I will personally try this soon, but apparently braided stain less steel brake lines diminishes pressure lossthat takes place with stockexpanding rubber brake lines.
ORIGINAL: Spike555
When was the last time you flushed the brake fluid?
