brand of motor oil---2003 Discovery
Old Mar 21, 2011 | 01:54 PM
JKFL03's Avatar
Originally Posted by kpl1228
ok---just picked up the filter, will get the Rotella T6 on my way home---15w40
Friendly reminder 6 Qts
Old Mar 21, 2011 | 02:13 PM
Bundu's Avatar
Banned
FYI... Rotella T6 does not come in 15W40.
Old Mar 21, 2011 | 04:02 PM
kpl1228's Avatar
ok guys, I need specific....WHICH Rotella (for summer use)? I'll pick it up tonite but i need the specific type.
thanks
Old Mar 21, 2011 | 04:12 PM
mwindth's Avatar
thanks
Rotella 15w-40 dino oil is what I use in warmer months and T-6 synthetic 5w-40 in the colder months.
Old Mar 21, 2011 | 04:30 PM
RAYMAN975's Avatar
i have used rotella 15w40 dino since i got my rover 20k miles ago. but my last oil change i put 5w40 rotella t6 synthetic in it. will it affect the engine at all to switch back and forth? if i choose to use the dino 15w40 in the hotter summer months for my next oil change. and then back to the synthetic 5w40 next winter? just curious, both oils make the engine run really well, im very pleased with them
Old Mar 21, 2011 | 04:59 PM
mwindth's Avatar
IMO it does not make a difference as long as you drain and re-fill (w/new filter of course) every 5K and keep the right weight per temperature.
You kinda answered your own question with the quote "both oils make the engine run really well, im very pleased with them"!
Old Mar 21, 2011 | 08:41 PM
thanks
Forget the "T's" and the "6's" and the "whatever's" and just buy 15w-40 for the summer and 5w-40 for the winter, all you care about is the viscosity and the brand.
Rotella is a well known and well respected motor oil and you can buy it almost anywhere.
So if you are on vacation and you need to add a quart you can find it easily.
Old Mar 22, 2011 | 12:05 AM
sloppyjoe's Avatar
im a mobil 1 high mileage user. 10/40.
Old Mar 23, 2011 | 10:11 PM
kpl1228's Avatar
Got the Mobil1 filter and the Rotella T 15W-40 and it's done. Thanks guys
Old Mar 23, 2011 | 10:52 PM
DiscoRover007's Avatar
I've got a question about oil as well. I've been running 20w-50 for the past year(Castrol, Valvoline, Penzoil). I'd like to switch to a lighter weight, and synthetic if possible for a bit better gas mileage. My concern is that my car has about 130,000 miles, and I currently have no oil leaks at all(I think it's a first) and just replaced a head gasket. I'm afraid that switching to a lighter weight might cause seeping or encourage another leak to pop up.
Is it worth the change or should I just stick to conventional 20w-50? (NC Weather btw)
