Breather Location
Old Oct 9, 2015 | 10:20 AM
arahim93's Avatar
Default Breather Location
Trying to locate my breather hoses so I can run them to a higher location. The diff breathers I have located, I can't seem to find the transfer case, and transmission breather hose. Can someone please put a pic, or direct me where to look. Thanks.
Old Oct 9, 2015 | 10:48 AM
drowssap's Avatar
under the hood up by the booster, it will be the one piece of tubing with out any connection. iirc
Old Oct 9, 2015 | 12:49 PM
lordmorpheus's Avatar
Behind the engine against the firewall. One comes up behind the passenger side of the engine and has a shepherds hook on it.
Old Oct 9, 2015 | 05:27 PM
arahim93's Avatar
Ok, I will try to look tomorrow, I was trying to find on the transfer case side and the transmission side, but if they are already ran into the engine bay I won't mess with it, will just make sure that they are still there. I just didn't want to risk taking in water.
Old Oct 9, 2015 | 05:51 PM
The only breather that doesn't already run into the engine bay area is the rear axle tube. Refrigerator ice maker water line comes in a very similar size. The clip on the axle is a quick connect clip - push down on the clip where it holds the tube, and the tube comes out. I then ran a line from the axle to the engine bay with the afore mentioned ice maker line.
llPANCHOll
Apr 10, 2009 06:40 PM
Disco Alan
Mar 30, 2009 11:46 AM
Roveroh
Aug 7, 2008 09:42 AM
falcontech
Feb 5, 2008 04:04 PM
brianex
Jan 9, 2008 09:08 PM
