British Submarine
Old Apr 2, 2023 | 10:53 PM
zacharyz28's Avatar
Default British Submarine
Went for a swim, below. Got water in the BCM and the ECM (at least) and now she wont start. If I can't dry them out and get them working how do i replace them? I head they are a matched set with the gauge cluster? So if I got a BCM, ECM, and Gauge Cluster from a parts car that should work? What else would i need?
Thanks
Old Apr 3, 2023 | 10:39 AM
gecko951's Avatar
Buy a big bag of rice, pull the BCM and ECM, open them up and bury them in your bag of rice for a week or two and they will probably dry out and work again.
Old Apr 3, 2023 | 05:08 PM
Harvlr's Avatar
And I think you can take the cover off the boxes to help them dry.
Old Apr 3, 2023 | 06:57 PM
zacharyz28's Avatar
I have taken them apart, cleaned the mud out, and dried them. Still dead. Going to need to get new ones.
Old Apr 4, 2023 | 08:26 AM
Extinct's Avatar
Yes, you need a matched set. IC is optional but it will flash the odo unless you turn it off with a nanocom. You will need to turn on the ignition and leave it on for 20 mins to allow the new bcu-ecu to sync with the interior fusebox, or you can get the matched fusebox too (not a bad idea ot have a spare).
Old Apr 10, 2023 | 12:48 PM
zacharyz28's Avatar
If I get a donor ECM/BCM/Gauge cluster does it have to be out of a non ACE car (mine doesn't have ACE)? I imagine it has to be out of a non SAI car since mine is non SAI.
Old Apr 10, 2023 | 06:48 PM
Extinct's Avatar
Yes, needs to be similarly equipped if you are going to diy, not so much if you are taking it to a shop that has a testbook programmer and knows what they are doing.
Fastercat
Jul 5, 2018 06:54 AM
Fastercat
Dec 3, 2017 09:01 PM
KingKoopa
Nov 11, 2017 09:55 PM
Best4x4
Oct 12, 2015 10:27 PM
abran
Apr 23, 2015 02:52 PM
