Britpart Extended Brake Lines
Old Feb 20, 2014 | 04:14 PM
roverwoody's Avatar
Default Britpart Extended Brake Lines
I have in the kit 2 different length in sizes. Long and short. Where does the shorter ones goes and I can figure out the longer ones?
Old Feb 20, 2014 | 06:24 PM
ralphobell's Avatar
How many in the kit total? 4 or 6?
Old Feb 20, 2014 | 06:26 PM
ralphobell's Avatar
If you have 6 in the kit then the shorty's go here.
Old Feb 20, 2014 | 06:34 PM
ZGPhoto's Avatar
There should be 4 IIRC, long ones I believe are rear axle. They should correspond to the lengths of the ones you're removing.
Old Feb 20, 2014 | 07:39 PM
roverwoody's Avatar
I have this kit.
Attached Thumbnails Britpart Extended Brake Lines-forumrunner_20140220_173738.jpg
Old Feb 20, 2014 | 07:48 PM
ralphobell's Avatar
OK then ignore my post. Go with ZGPhoto's comments.
Old Feb 20, 2014 | 07:54 PM
toofaroffroad's Avatar
Long ones go on the front short ones go on the back. The front cables are much longer then the back.
Old Feb 20, 2014 | 09:08 PM
roverwoody's Avatar
Thanks. I double check and take the front and rear off and compare them to see which is longer.
cybercop
Nov 15, 2014 11:09 PM
cruzer555
Dec 27, 2013 04:37 PM
ZB-30
Jul 10, 2012 03:22 PM
bosshogt
Sep 9, 2010 07:31 PM
raid13
Jan 16, 2009 03:49 PM
