Stainless Steel Brake Lines Regular or Extended?
Old Jul 10, 2012 | 08:24 AM
ZB-30's Avatar
Default Stainless Steel Brake Lines Regular or Extended?
I have a 2" OME lift on my 04 Disco and I 'm looking to replace the stock brake lines with some stainless steel ones. I just don't know if I should go with standard length lines or go for the extended lines. Looking at the existing lines the front ones looke like they are plenty long enough but the rear ones look like they could use a couple of inches. Opinions?
Old Jul 10, 2012 | 08:28 AM
If you have plans for larger tires and a lot of fun wheeling, yes go to the extended length to be make sure you don't have an issue.
How many miles on your truck?
Old Jul 10, 2012 | 08:32 AM
ZB-30's Avatar
I plan on getting some 245/75 R16 BF Goodrich All Terrains here in the near future. My milage is 81200.
Old Jul 10, 2012 | 08:34 AM
You are in a grey area, if you will be doing a lot of wheeling go longer.
At your mileage, you might also consider replacing all 6 rubber brake lines cause they all wear with time.
Old Jul 10, 2012 | 03:22 PM
ebg18t's Avatar
Add the extended stainless lines.
Orkney LR4
LR4
Dec 4, 2013 10:26 AM
blurover
Nov 29, 2013 01:26 PM
potxoli
Sep 3, 2013 03:04 PM
nahtanoj
Jun 4, 2012 11:44 AM
bosshogt
Sep 9, 2010 07:31 PM
