Britpart SS brake hose kit
Old Nov 27, 2018 | 10:36 AM
DiscoBuckeye's Avatar
Default Britpart SS brake hose kit
Anyone installed these? I just ordered a set to install with my 3" HD lift I got from Lucky8. I am so stoked about lifting her!!!!
Old Nov 27, 2018 | 11:07 AM
Best4x4's Avatar
I have a set of them on my 02 Kalahari (was supposed to be the 50mm TF SS brake lines), but oh well. I installed the 40mm extended SS brake lines & I matched up the angle of the OEM lines (I’ve seen some people mount them aiming straight back which to me seems wrong as it could cause a kink/pinch point). Make sure to route them to where they go away from the coil springs during suspension travel. I’ve seen several people pinch their new lines from improper routing & the coil spring goes town on it.
I used my 15ft cable lead, toggle switch to the ABS relay to quickly power bleed the system. Entire job was right at an hour and I took my time. “If” you plan on doing some serious flexing with the rear swaybar removed/disconnected I’d highly recommend extending the rear ABS sensor cables. Quickest/most cost effective way to do it, is to install a pair of front ABS sensors on the rear. You can get a set online from 20-30.00 vs the 200.00 Wabco ABS sensor extensions.
Overall I’m very happy with them!
Old Nov 27, 2018 | 11:20 AM
awesome! Did I mention I was excited about getting the lift in? Lol its 20 degrees outside
MacRoadie
Aug 18, 2021 08:49 AM
cruzer555
Dec 27, 2013 04:37 PM
FlyingZebra34
Jul 4, 2012 10:57 PM
hilltoppersx
Nov 6, 2010 10:06 AM
rj95lss
Sep 22, 2009 03:29 PM
