Broke off the plastic nipple on radiator
![Wink](https://landroverforums.com/forum/images/smilies/Uh2vXQr.png)
![EEK!](https://landroverforums.com/forum/images/smilies/bmHv6Xb.png)
Are you able to post a photo of what this nipple thingy is whereabouts on the rad. Id it plastic? and is it under rad pressure? Photo woul be useful.
![Smile](https://landroverforums.com/forum/images/smilies/H5uKDcM.png)
It's the coolant recovery nipple on the top of the radiator.
I picked up one of these and I'm going to drill out the broken off piece, tap it and try this guy.
![](http://ecx.images-amazon.com/images/I/41WkTkV7GQL._SX342_.jpg)
Ya I'm a trial by fire kinda guy
Edit : In all fairness I cut the roof off the pathfinder, built a roll cage and turned it into a beast. It was bound to happen.
I tried to do this and got cold feet and ordered a new radiator without testing it. But I think the fix would have worked pretty well.
I'd suggest using a multi-step drill bit to tap the hole in the plastic. I used a regular drill bit and it did not go very gracefully which is why I bailed on it. With a multi-step bit, you could create a great seal with your nipple above. Something like this:
https://www.google.com/shopping/prod...d=0CKcCEKYrMAs
Then I'd encase the whole thing in epoxy.
I ended up using a small saw to get most of the nipple off, sanded it down, drilled it out to a 3/8" and tapped it with a 7/16-20"
Wrapped the threads in teflon tap (melting point of 600F-ish ?).
It still has a slight leak at 4,500rpm so once it's all cooled down I'm going to take it apart again and add more tape. If that doesn't work epoxy will.
Normally I would just replace the radiator and I was planning on putting in that all metal one but sadly I opted for putting it up for sale. I'm just adamant on it being "leak free"
bcolins
06-02-2011 07:40 PM
