Broke off the plastic nipple on radiator
Old Sep 14, 2014 | 11:27 AM
FlyingZebra34's Avatar
Default Broke off the plastic nipple on radiator
Anyone have a Land Rover fix for the rather than replacing the radiator? I saw someone awhile ago use some kind of threaded metal piece to re create the nipple thing.
Looking for a band aide fix for this.
Thanks guys
Old Sep 14, 2014 | 03:42 PM
OffroadFrance's Avatar
Thanks guys
Looking at the 'end result' of some of your trucks you ain't having a lot of luck eh. Maybe go get a Sherman tank
Are you able to post a photo of what this nipple thingy is whereabouts on the rad. Id it plastic? and is it under rad pressure? Photo woul be useful.
Old Sep 14, 2014 | 06:54 PM
It's the coolant recovery nipple on the top of the radiator.
I picked up one of these and I'm going to drill out the broken off piece, tap it and try this guy.
Ya I'm a trial by fire kinda guy
Edit : In all fairness I cut the roof off the pathfinder, built a roll cage and turned it into a beast. It was bound to happen.
Old Sep 15, 2014 | 07:10 AM
Looks good. It looks like a BSP tapered thread to me so be careful when screwing into plastic otherwise you may split the plastic rad top. Use a waterproof sealant around threads, Loctite or similar but ensure it's totally dry first and leave for the requisite recommended time to set. Good luck and not too hamfisted when tapping the plastic and screwing the nipple in.
Old Sep 15, 2014 | 09:09 AM
potxoli's Avatar
I tried to do this and got cold feet and ordered a new radiator without testing it. But I think the fix would have worked pretty well.
I'd suggest using a multi-step drill bit to tap the hole in the plastic. I used a regular drill bit and it did not go very gracefully which is why I bailed on it. With a multi-step bit, you could create a great seal with your nipple above. Something like this:
https://www.google.com/shopping/prod...d=0CKcCEKYrMAs
Then I'd encase the whole thing in epoxy.
Old Sep 15, 2014 | 11:30 PM
I ended up using a small saw to get most of the nipple off, sanded it down, drilled it out to a 3/8" and tapped it with a 7/16-20"
Wrapped the threads in teflon tap (melting point of 600F-ish ?).
It still has a slight leak at 4,500rpm so once it's all cooled down I'm going to take it apart again and add more tape. If that doesn't work epoxy will.
Normally I would just replace the radiator and I was planning on putting in that all metal one but sadly I opted for putting it up for sale. I'm just adamant on it being "leak free"
Attached Thumbnails Broke off the plastic nipple on radiator-img_20140915_214248_500.jpg
Colorado David
Nov 1, 2025 10:10 PM
calebbo
Aug 27, 2014 10:07 PM
steveo2000
Sep 1, 2011 03:14 PM
bcolins
Jun 2, 2011 07:40 PM
DavidG
Jul 11, 2009 09:38 PM
