Broken Bleed Screw - Dorman Replacement part?
Old Nov 17, 2020 | 12:56 AM
Chris59's Avatar
Default Broken Bleed Screw - Dorman Replacement part?
My bleed screw unfortunately broke in half. Autozone carried the following part I found by searching for a bmw bleed screw mentioned on this forum.
Any thoughts/warnings? I used the old larger oring. The length is slightly different.
Old Nov 17, 2020 | 04:17 AM
JUKE179r's Avatar
Go for it. It'll work.
I've got this documented on my Disco 2 cheat sheet:
"- Radiator Tee bleed screw Dorman #902-404; same bleeder screw on BMWs from 1985-2009 and on Mini Coopers"
Old Nov 17, 2020 | 10:08 AM
Richard Gallant's Avatar
@Chris59 I have a container of those bleed screws I scavenged from wrecked BMW's I carry in my Disco after one cracked. They work fine.
Old Nov 17, 2020 | 03:40 PM
Extinct's Avatar
I have a bunch of spares I can send you if you pay shipping, how many do you want? Also, I have one brass one.
Old Nov 17, 2020 | 03:54 PM
Chris59's Avatar
I bought the screw, but is it worth having an extra tee (the whole unit)? Has this ever failed on you?
Also, any advantage to a brass screw other than it won’t break? I was worried it would leak or I would damage the plastic threads.
Old Nov 17, 2020 | 04:25 PM
jastutte's Avatar
i had a Tee fail on me. it crumbled and then broke all at once. fortunately, i had a couple spares lying around.
go with the brass screw. one less thing to worry about breaking.
Old Nov 17, 2020 | 04:33 PM
Discorama's Avatar
I used this: https://www.ebay.com/itm/Brass-Upgra...8/251549467194
Old Nov 17, 2020 | 04:37 PM
Chris59's Avatar
Is it likely a broken bleed screw would cause a large coolant leak? Just surprised I lost so mush coolant through a tiny crack - I suppose the pressure helps with that. My engine was covered.
Old Nov 17, 2020 | 06:38 PM
Extinct's Avatar
You are asking the wrong question, you should be asking why I have so many spares. Search for the last post from Pete C. Or search for inline thermostat.
Old Nov 17, 2020 | 06:58 PM
Chris59's Avatar
ah, clearly I didn’t spend enough time looking at your kit instructions. Tee/screw is eliminated? Well, since your kit should arrive before this weekend I suppose I no longer need screw.
