broken clip mount for the air box lid to air mass airflow sensor--can it be fixed?
Seems a common problem,...as all 3 of my Disco IIIs have had this issue. The plastic mounting points for the clips that secure the air filter assembly/box lid to the Mass airflow sensor tube are broken. One has been completely missing since I bought the truck a year and a half ago,...and the other broke partially yesterday.
Has anyone found a way to secure the lid of the air filter box to the MAF using maybe wire ties or stainless safety wire? Has anyone found an adhesive that will permanently re-secure the partially broken clip mount on the Air Box lid?
BC in Austin
BC in Austin
I did this fix....I found that the clips were pretty poorly made and don't hold very well, but it may be due to were I placed them
https://landroverforums.com/forum/di...lip-fix-58556/
Am not there yet, mine still fine. After regrooving the plastic for a clip to stay put from cover to filter box.
But attaching strong magnets to box and cover should work if I need to. The best latch there is not needing a latch.
For the air sensor intake, the solution above seems fine.
