Broken/Cracked EXTERIOR WINDSCREEN TRIM PANEL?
Old Jan 23, 2017 | 06:52 PM
cobancrawford's Avatar
Default Broken/Cracked EXTERIOR WINDSCREEN TRIM PANEL?
This plastic piece in on either side of the windshield running from the top to bottom of the windshield. I think it is called the EXTERIOR WINDSCREEN TRIM PANEL, although im not quite sure. If you know the name or where I can buy new ones id appreciate it, thanks. Discovery 2 2001
Broken/Cracked EXTERIOR WINDSCREEN TRIM PANEL?-s-l300.jpg
Old Jan 23, 2017 | 08:16 PM
Luckyjayb's Avatar
Exterior a pillar trim. Lucky8 has both sides with Rivera for around $220. Atlantic British is higher but you can also check eBay. Atlantic British has a good video on removing and replacing them though if you need a quick guidance.
Old Jan 24, 2017 | 10:15 AM
Street Wolf's Avatar
Only one worth picking up is a fiberglass replacement, OEM style cheap plastic is just going to break yet again.
LAND ROVER DISCOVERY 2 TD5 PAIR OF A PILLAR EXTERIOR WINDSCREEN TRIM PANEL | eBay
Old Jan 24, 2017 | 01:22 PM
Luckyjayb's Avatar
LAND ROVER DISCOVERY 2 TD5 PAIR OF A PILLAR EXTERIOR WINDSCREEN TRIM PANEL eBay
my only issue with those are they are attached with 3m double side adhesive tape. Those guys are fixing to shut down for the Chinese New Year. I'm in talks with them to build me a Saudi style grille out of fiberglass as we speak
Old Jan 24, 2017 | 03:02 PM
D24.6's Avatar
I got these awhile ago and very happy!
Old Jan 24, 2017 | 05:37 PM
Luckyjayb's Avatar
good to know. I've been checking them out but was a bit cautious
Old Jan 24, 2017 | 05:39 PM
Luckyjayb's Avatar
That and I'm debating the fiberglass windscreen cowl from Miami British
Old Jan 24, 2017 | 09:46 PM
Agreed, but after seeing and installing a couple of sets, I actually like it better.
Old Jan 24, 2017 | 10:02 PM
Luckyjayb's Avatar
i figured they worked ok since the side molding is attached that way but I was worried about the pressure washing and wind
Old Jan 25, 2017 | 09:42 AM
matt3502's Avatar
I had my windshield replaced at a well know company. They broke the cowling and got me a replacement. I think it was the fiberglass one. Did not last 2 months.
