Broken piston
Old Dec 5, 2012 | 03:45 PM
coors's Avatar
Yep. Sounds like the rod snapped.
Give us some background.
Why did you initiate the tear down? What symptom/s prompted you to tear it down? Did you have a rod knock prior to the tear down?
Old Dec 5, 2012 | 03:50 PM
DustyLBottoms's Avatar
Originally Posted by Scott Crutcher
Thanks for the reply, I'll pull the oil pan and see what I find.
Pay particular attention to the crank journal and the cylinder wall. You might be in it for a Crank or a block.
Old Dec 5, 2012 | 03:57 PM
04duxlr's Avatar
If you can push one piston down in its bore without any of the others moving then you have either a broken wrist pin (not likely), a piston broken just below the rings (not likely) or a broken connecting rod. I suppose a broken crank is another possibility but I've never heard of that happening in these engines. Was this vehicle picked up as a non-runner or did it stop running while you owned it?
Old Dec 6, 2012 | 12:44 PM
Scott Crutcher's Avatar
4wd High
I pulled the oil pan and took a look - didn't like what I saw. Looks like the connecting rod snapped and lodged into the side of the block. Where do I go from here? New block? Buy a used engine and swap them out? The truck is currently in Kansas City. Wonder if I can get a donor truck with a decent engine around there?
Old Dec 6, 2012 | 01:34 PM
drowssap's Avatar
pictures would help, it possible the block can be saved, it will have to be re-sleeved though.
I see your in CA. there is a company in out the that specizes in sleeving rover block LA machine or LA sleeve something like that.
It's that or a used motor. what about the crank? if the crank is damaged just find a motor, you will spend twice the money on machine work
LRScott
Apr 9, 2009 01:44 AM
azazel_18_2
Engine & Internal
Nov 16, 2008 08:35 AM
smllikphysh
Oct 27, 2008 06:44 PM
cterrebonne
Engine & Internal
Oct 14, 2006 07:47 PM
sanchez
Aug 3, 2006 10:24 PM
