Sponsored by: CARiD
retraction of piston in rear caliper
Old Oct 26, 2008 | 01:51 PM
smllikphysh's Avatar
3rd Gear
Default retraction of piston in rear caliper
Trying to put new rear pads and discs on my sons discovery. Removed left rear caliper and pads. To remove frozen disc I had to put in neutral gear to rotate disc. Stepped on brake to disengage gears and piston extended out of caliper, not enough to remove rubber boot. I cannot get piston to slide back into caliper. With other cars I have simply used a clamp to retractthe pistonor rotate piston in like a screw. I have also opened bleeder valve to release fluid pressure but nothing I've tried works. Thanks for any help, Mike
Old Oct 26, 2008 | 02:01 PM
Default RE: retraction of piston in rear caliper
If there is not too much damage, you may be able to rebuild that caliper, most likely though a remanufactured one would be better.
Old Oct 27, 2008 | 01:15 PM
3rd Gear
Disco Mike, Thanks for the reply. I removed the caliper and was able to retract piston with a vice. It was too late to bleed and I will have to do it when I get home. Any chance no permanent damage was done? Mike
Old Oct 27, 2008 | 06:44 PM
That will be determined by a visual inspection.
Externet
Mar 27, 2015 12:33 PM
DSCVRY
Nov 30, 2014 11:38 AM
airmarc
Jan 11, 2012 12:01 PM
bhorwhat
Oct 29, 2008 12:55 AM
