Broken Rear Sunroof: cable frame and/or motor spindle?
Old Jul 11, 2022 | 02:18 PM
Extinct's Avatar
Here are the pics. The track frame is held to the upper half of the sunroof frame with screws. Once you have the lower pan out you can lift the entire assembly out from the top then work on it one the bench.
This is the slot in the glass carrier that the cable pin runs in, this is what tilts the glass up.
The arrow points to the square track bushing, the pin on the cable boss runs in one and the pin in the glass carrier runs in the other (not shown). 90% of the time the pin on the cable boss breaks off.
The cable end on the right drives the cable boss.
Old Jul 12, 2022 | 08:01 AM
austinlandroverbill's Avatar
Great pics, thanks Extinct.
Removed "wheel" from my D2 sunroof lexicon, from now on it is a "peg",
I am going to stick my head up in there and see if the peg(s) has sheared or if it otherwise got out of the track. Now that I see the whole mechanism, I am going with a sheared peg.
Can the peg be repaired/replaced in-place, or is my best bet if the peg is sheared to just get a "new" frame/cable assembly from a donor?
I am pretty much resigned now to pulling the headliner (this will actually be the third time I've done it: first time to renew a sagging headliner, second time to replace the fat roof rails that came with the '04 with skinny rails with the full roof extension) as it will give me the opportunity to also replace the sunroof ECU to see if that fixes the ghost roof opening issue (which I am think probably put the pegs thru too many cycles, causing it to break).
Nashvegas, can you say more about this sealant you used for the top frame assembly. I am worried that any 3M product is "permanent", and that once sealed, I won't be able to get that top frame off again in case I need to in the future.
Old Jul 12, 2022 | 08:02 PM
Extinct's Avatar
Use normal window silicone for the sealant. You probably should probably plan on sunroof rail replacement.
me 2
Jul 10, 2022 10:42 AM
roverfogg
Jun 18, 2020 01:39 PM
za105
Dec 13, 2019 02:48 PM
jamestfl
Apr 11, 2019 03:14 PM
me 2
Sep 15, 2014 07:20 AM
