Broken upper shock bolt!
Old Nov 15, 2016 | 12:40 AM
Island_Dave's Avatar
Default Broken upper shock bolt!
Well this sucks... was replacing my rear shocks when the top bolt, passenger side snapped. Half the bolt is still holding the shock in place... just... the end that is still in place is likely sheared right back to the retaining nut
access is tight - can't think of a worse place to get in and try and extract a sheared bolt to be honest.
anyone had to deal with this before?
Old Nov 15, 2016 | 04:41 AM
The Deputy's Avatar
If you have access to a compressor and a Pneumatic cutting wheel...cut the steel portion of the upper shock that goes around the rubber bushing, cut in two places so it will eventually move out of the way, then cut the rubber bushing with a razorblade knife. Once you are that far, take a small torch and heat the threaded end, while turning the rest of the bolt with a pair of locking vise grips pliers.
If you don't, you could always drill the bolt out. Might need an off-set/angled head drill, but they are worth buying and having anyway. Then just drill out the rest of the broken bolt and replace with a new through bolt and nut.
St. Louis Pneumatic 4 in. Cut-Off Tool with Cutting Wheel-SLP82032 - The Home Depot__
Irwin Vise Grip 10Wr (#0502L3) Curved Jaw Locking Plier
3/8" Angle Head Air Drill
Both of these tools are available in a electric models also.
Good luck,
Brian.
Old Nov 15, 2016 | 11:42 AM
Thanks Deputy... worth a try but judging by the snapped end of the bolt that came out, there's not going to be much left to try and get a grip onto. FML.
twr7cx
Jul 4, 2012 07:52 PM
shaggy52282
Apr 28, 2012 05:12 PM
twaszak
Jun 27, 2011 04:21 PM
tornado_735
Dec 4, 2010 06:32 PM
