Bulge in my...rad hose coolant temp is low..
Old Apr 21, 2022 | 10:30 PM
krustacean's Avatar
Originally Posted by ahab
At least in the later trucks, the ECU gets its temp info from the CTS in the intake manifold. I'm not sure what the one in the radiator does, some trucks don't have that. My '04 doesn't and my '03 is a complete '04 swap so neither does it. Not sure about the '02. It takes a while for the lower hose to get hot to the touch. If you just let it idle a few minutes and it didn't get hot then that's not a good test. If you drive it a round for a bit it should get hot. Could be a bad cluster/gauge too.
makes sense since my interior heating is nice and toasty. I didn’t get a chance to drive it around, i was idling for about 20 minutes and it hit the first mark on the cluster gauge and didn’t go up from there. Thanks for the useful tips!!
Old May 1, 2022 | 04:05 PM
krustacean's Avatar
UPDATE!! replaced the coolant temp sensor up top and bingo. Getting the gauge to the middle feels great! Problem resolved.
Old May 2, 2022 | 01:02 PM
tnrangerover's Avatar
you still need to replace all the plastic and hoses in your cooling system. also, would recommend getting a way to read actual temps. The needle will show middle of the gauge from about 150-230 degrees before it moves up, and 230-240 is already too hot IMO.
Old May 2, 2022 | 01:17 PM
krustacean's Avatar
thank you! Yes, hoses replaced and bleeder/thermostat also. But good idea re actual values…I’ll drive it with my scanner on and turn on live data….
Tristan Stumpf
Aug 1, 2025 04:46 AM
RyanLR3
Jun 8, 2021 03:29 AM
Poorfish
Oct 19, 2017 08:12 AM
slanginsanjuan
Nov 22, 2011 11:14 AM
vinvelasco
Aug 17, 2008 07:47 AM
