Buying a 99 Disco Trek
Old Apr 10, 2007 | 07:15 PM
progolfer_20's Avatar
Default Buying a 99 Disco Trek
I am going to buy a 99 Discovery Trek, 58K on it now. Safari rack, Warn 8000i winch. Roof rack. Buying for 13.9K Just had a new front drive shaft and greaseable u joints installed.
Is there anything to watch out for? It looks like this is a good rover. The owner worked for the dealership for the last 5 or 6 years and all the maintenance was completed with proper markings from the dealer thru 52.5K service.
The 60K Service is coming up, anything to look out for?
Old Apr 10, 2007 | 07:33 PM
Default RE: Buying a 99 Disco Trek
The 60,000 K is way past due. It is supposed to be done every 60,000 or 5 years so plan on doing that asap.
You will be need ing new plug wires, don't use Rover wires, I would suggest you order a set of 8mm Magnacor wires. As part of the service, change all fluids completely and consider doing an engine flush and a induction cleaning to clear out the carbon.
Good luck with the new truck,
Mike
LR600
Mar 24, 2011 09:15 AM
yloDiscoII
Oct 25, 2010 10:21 AM
lbangert
Dec 18, 2008 10:53 PM
R_Lefebvre
Jan 12, 2008 10:28 PM
spence426
Oct 25, 2007 09:43 PM
