Buzzing Relay with TC and HD Light
04 DII
The Traction Controll and Hill descent light come on and the truck shuts off.
When it quits - Relay #9 (shown as "MAIN RELAY") is buzzing.
If you wiggle/pound on/remove and replace/ the relay - the buzzing stops and the truck will start. The truck will then run for 30 seconds to 5 minutes before it shuts of.
I replaced the relay with the same result.
I unplugged all conectors - sprayed with contact cleaner reasembled with the same result.
Recently changed the water pump and installed PIAA's
Thoughts?
What is my next step?
Thanks,
Jackson
Thoughts?
Thanks,
Jackson
Did this all start after installing the PIAA's?, if so that's where I would be looking. Undo whatever you did to install the lights and see if the problem goes away. Depending on where you powered up your lights, you may have melted some wiring due to running excessive amperage through some wires. Might be worthwhile to look at the backside of the relay panel for signs of overheating.
