A/C compressor kicking on and off.
Old Jun 6, 2013 | 10:37 AM
kfx4001442's Avatar
Default A/C compressor kicking on and off.
2000 Disco II. 140K. I checked all my fluids yesterday and after gave the engine compartment a good visual inspection while the engine was running. I noticed that the A/C compressor kicks on and runs for awhile then it kicks off, but will kick back on after about 15 seconds. Air is blowing ICE COLD out the vents. Is this normal and I've just never noticed, or does my A/C system need some attention?
Old Jun 6, 2013 | 11:43 AM
johnnyjohnny's Avatar
I've noticed that on my 2003 as well. It makes a loud click each time it stops. AC works fine, and I haven't really done anything about it, so I'm interested to hear what people have to say.
Old Jun 6, 2013 | 12:40 PM
drowssap's Avatar
it probably cycling on and off like that because is low on gas, but it hard to say with gauges on it.
Old Jun 6, 2013 | 01:38 PM
jfall's Avatar
air is blowing out cold.
Leave it alone!
Old Jun 6, 2013 | 04:20 PM
All a/c system cycle on and off and for the ones that cycle too often it is low on freon and a small recharge on your part will allow it to blow much colder with less run time.
Old Jun 6, 2013 | 07:26 PM
X2 on the low gas. Cold is a relative term, just like running hot.
Old Jun 7, 2013 | 10:01 AM
SuperSport's Avatar
Autozone now carries those easy to use cans with built in gauges. Not sure how accurate they are, but I'm sure they're close enough. OH, are we even 134a? I have not looked yet.
Old Jun 7, 2013 | 10:08 AM
I have had and used that product for the last few years, just to top of my 14 year old D2 a/c system, makes all the difference in the world. Actually I have had the same can and for the amount I use it has lasted those last few years, makes it even a better deal.
By the way, Advanced Auto has it on sale for $5 off if you receive the monthly mailer.
Old Jun 7, 2013 | 10:12 AM
SuperSport's Avatar
Also, the Gauge is reusable, so you only replace the can for future fills for $25.
If you watch This Video, it gives a very SIMPLE and detailed guide on how to check and fill your system, even for a first timer.
Old Jun 7, 2013 | 10:53 AM
gaping46and2's Avatar
7th Gear
If you have a Big Lots around you, they sell these guys for about $15-$20 with the reusable gauge, and new cans are like $5 each. Most auto places are like $40 or $50.
