A/C Condenser Fan Not Working
Old Apr 10, 2019 | 04:20 PM
Fast951's Avatar
Default A/C Condenser Fan Not Working
I just replaced a seized electric fan with a salvage fan that is good. Tests on the bench just fine but does not power up in the truck when the A/C is switched on. Checked the 40A red fuse (it was good) and swapped the yellow fan relay in the under hood fuse box but still does not turn on. Used a meter to check for 12V power at the connector and there is none. Ideas?
Old Apr 10, 2019 | 05:07 PM
Best4x4's Avatar
It will only turn in when the AC needs it. It doesn’t always come on instantly upon turning the AC on.
Old Apr 10, 2019 | 07:12 PM
redwhitekat's Avatar
Block the rad with a plastic bag temporarily pressures should rise in the ac system providing power to your fan
Old Apr 10, 2019 | 08:53 PM
ahab's Avatar
Or try putting a hairdryer on the temp sensor near the condensor, tricking the ECU into thinking it's hot out? I think there's more than one sensor to trigger HVAC, but that may be enough.
Old Apr 10, 2019 | 10:10 PM
Ben Matheson's Avatar
System won't turn on the fan unless it's over 76 degrees. Also a speed sensor somewhere that turns it off on the highway
Old Apr 10, 2019 | 10:22 PM
ahab's Avatar
OK, so unless the hairdryer only goes to 76°, and you have the truck on a 4 wheel dyno simulating highway speeds, I think it's still a valid test.
Old Apr 10, 2019 | 10:24 PM
You are correct
Old Apr 10, 2019 | 10:27 PM
ahab's Avatar
At least we're on the same page then
Old Apr 10, 2019 | 10:37 PM
Yep just giving him a temp to shoot for
Old Apr 11, 2019 | 08:19 AM
zuke's Avatar
Just jump the relay for the fan.
