A/C fan not working
Old May 24, 2012 | 12:49 PM
  #21
Briankramer's Avatar
Do you remeber witch two wires you jumped I think I have the same problem
Originally Posted by Enigma753
Despite the age of the thread it has been most helpful, I experienced the exact same problem.
From this thread I used a jumper wire where the relay is suppose to be, and the system works normally.
I will be replacing the relay but I have notice inconsistent prices, from 89 dollars to 26 dollars.
Is this correct??
Thank you for the thread.
Old May 25, 2012 | 10:16 PM
  #22
PalmettoDisco's Avatar
Check out my fix from long ago in the link below. Check for power at the fuse indicated(front panel at fuse). If no power loosen top bolt holding fuse block and pull top of block toward you to get to back. Check for power on connector and wire indicated. If you have 12V then your fuseblock is bad internally for the blower fuses (rest of block typically is fine). Either replace block or bypass as indicated. Good wire from back to wire from blower with an inline fuse. If no power found then check fuseblock under the hood(bonnet) as indicated. Bypass there if needed as indicated. I had problems with both and bypassed both. Working fine years later.
https://landroverforums.com/forum/di...m-fixed-22524/
Old Jun 1, 2012 | 02:19 PM
  #23
Thanks alot for this great write up. I had the same problem with the front and rear a/c blower not working. Some reason I had 11volts to fuse 6 and 7 with it off, as soon as I turn the a/c on it dropped to 0volt. so Just did a quick check with the a/c off, ran a wire with 30amp fuse from the battery straight to the blower relay (Brown/red wire). Then turned on a/c and wham it worked so I new that the fuse panel had a short in it so I put two inline fuses like you did. thanks just in time for another hot summer.
Old Jun 1, 2012 | 09:28 PM
  #24
Glad you have a/c back. I remember how happy I was when it worked.
Old Jul 9, 2017 | 10:34 PM
  #25
MPDano's Avatar
Finally got a round to working on mine. Fan also just stopped working months ago but now it's summer and much needed. I ended up pulling the interior fuse panel and cleaned and inspected with nothing out of the ordinary. Pulled the blower motor and had power going to the power plugs but seems to not have enough amps to move the blower motor. Tested blower fan direct hookup to battery and it was fine.
I ended up wiring in 10 gauge wire direct from the battery to the blower relay with a an inline 30 amp fuse, and disconnecting the stock power wire and capping it off.
Blower fan now works perfect. Had to charge the AC with a can of freon. I was also surprised the fan speeds also still function. Happy camper now.
tsuyoi
Sep 22, 2020 10:37 AM
sgianola
Sep 21, 2014 11:09 AM
2tooMany
Aug 28, 2012 09:39 AM
jycsalas
Jul 22, 2012 07:37 PM
