A/C howling noise
Old Aug 6, 2007 | 02:58 PM
baddiscoII's Avatar
Default A/C howling noise
Hey new to the site. Great stuff. I have a99 disco II V8 99000 miles. Recently the truck has went to pot. New water pump, starter and alternator redone. Now the a/c makes a howling noise when you turn it off. Had it looked at. Said maybe a compressor clutch or a bearing. Any ideas????? Also has anyone tried the slotted rotors?????? Pros vs. cons?????
Old Aug 6, 2007 | 05:13 PM
Default RE: A/C howling noise
You might want to give me a call, I can point you in the direction of a good guaranteed used a/c compressor.
Also I have been run DBA rotors and Kevlar pads for the last 60,000 plus miles.
Mike
303-862-7680
Old Aug 6, 2007 | 05:56 PM
baddiscoII's Avatar
Mike would this also be causing the a/c condenser fan to chirp and run constantly? What else has to be changed when you have the compressor changed?
Old Aug 7, 2007 | 01:07 PM
bigugly82's Avatar
Mike, Where did you get your rotors and pads?
gribur
Feb 14, 2015 09:37 AM
mx468
Nov 21, 2012 08:29 AM
30more
May 28, 2012 05:01 PM
geek_IM
Oct 4, 2010 11:02 AM
adrianwood
Freelander
Jun 13, 2005 08:53 PM
