a/c problem and other random question
Old May 14, 2012 | 10:41 AM
bballjames's Avatar
Default a/c problem and other random question
So I have an issue with my a/c. I have a 2000 disco series 2 with 137xxx miles on it. The a/c will turn on and blows fine. But it will only blow cold for a couple minutes. Then it goes warm. Any idea what the problem is?
Also, one other random question, sometimes when I am driving, the Rover beeps three times at me. No lights on the dash are lit, and the beeping is pretty irregular. Probably about every third or fourth time I drive it, sometimes more. I tried looking it up in the manual, but it sounded like there are a lot of different things this could be.
Lastly, when I turn the Disco over, all lights light up on the dash except for the ABS light at the top, and the D light on the bottom. All other lights light up. Is this normal? Or did someone tamper with it to cover some issues?
Thanks in advance for your help.
Old May 14, 2012 | 10:46 AM
gotmud's Avatar
your ac probly needs to be filled and checked for leeks and your lights should all be lit up when you first turn the key on you should have the codes checked
kog50
Aug 19, 2023 10:23 AM
DannyMcF
Jun 6, 2012 10:53 AM
adam123
Apr 5, 2011 09:11 AM
Street Wolf
Aug 12, 2009 03:11 PM
Sarge
Jun 4, 2005 07:57 PM
