A/c shows C* instead of F* ugh
Old Apr 14, 2010 | 10:55 AM
GARovee's Avatar
Default A/c shows C* instead of F* ugh
After disconnecting battery my ac display shows everything in celcius.. How do I get it back to F*?
Old Apr 14, 2010 | 11:13 AM
Shane83's Avatar
Turn the ignition on.
With the climate control turned on, push and hold the recirculation button in. While holding the button in, push and hold the off button in for 3 seconds or until you hear a beep.
The display should then change to “F”. Follow these same steps to change your read-out to Celsius , if preferred
Regards friend,
Old Apr 14, 2010 | 11:32 AM
If you have an owners manual, you might want to take an hour or so and read it.
As already mentioned it is an easy fix.
Old Apr 14, 2010 | 11:39 AM
hilltoppersx's Avatar
does your radio come on is the real question... and do you have the radio code just in case...
Old Apr 14, 2010 | 01:35 PM
GARovee's Avatar
My owners manual is at home and I'm at work wanting to know so :P yeah the radio works.. I've had the battery out a few times now and haven't had a problem. And no.. Don't have a code for it... Is it noted some where?
Old Apr 14, 2010 | 08:34 PM
Why is your owners manual out of the truck?
The security code for the stereo should be in the stereo owners manual.
Otherwise you will have to get it from the dealer.
Print this page and stick it in your glove box.http://www.RoverParts.com/TechTips/T..._C_to_F_D2.cfm
Cannonball55
Jul 21, 2012 10:17 PM
Draayer
Feb 18, 2012 07:33 AM
Spencerfitch
Aug 4, 2011 01:26 PM
Disco_Fever
Apr 26, 2011 11:59 AM
Butch
May 20, 2005 01:11 AM
