A/C Switch
Old 08-23-2007, 04:26 PM
bklahl's Avatar
Default A/C Switch
When I have my A/C on high Fan. It shuts off randomly and all I have to do is touch the switch and it comes back on. 96 disco. Does anybody know an easy fix?
Old 08-23-2007, 04:29 PM
chargersfan's Avatar
Default RE: A/C Switch
I'm watchin this one I have the same problem, or if I go on a bumpy road? Weird
Old 08-23-2007, 07:17 PM
Most likely the resistor pack that regulates the fan speeds is failing, don't run the higher speeds, running a slower speed actually allows the a/c to keep up with the heat and blow colder air.
Old 08-23-2007, 10:21 PM
okdiscoguy's Avatar
Mine does the same thing every now and then. Just touch the switch and it comes back on. Probably in the selector switch. I just haven't torn mine apart yet.
Old 08-24-2007, 07:50 AM
One might think it is the switch, but it is usually always the resistor pack which do burn out especially when you run your a/c in the high position.
Old 08-24-2007, 10:14 AM
okdiscoguy's Avatar
Why would just lightly touching the switch on the dash affect the pack under the dash? I trust your call Mike, just wondering.
Can you just replace the resistors? I haven't looked at the pack yet, but know where it is...
abran
08-05-2014 06:13 PM
AZRover
07-02-2012 06:43 PM
jaxrvr
04-24-2005 12:01 AM
garover
03-21-2005 10:10 PM
flyingcouch
01-22-2005 08:25 AM
Quick Reply: A/C Switch
