A/C Switch
Old Aug 23, 2007 | 04:26 PM
bklahl's Avatar
Default A/C Switch
When I have my A/C on high Fan. It shuts off randomly and all I have to do is touch the switch and it comes back on. 96 disco. Does anybody know an easy fix?
Old Aug 23, 2007 | 04:29 PM
chargersfan's Avatar
Default RE: A/C Switch
I'm watchin this one I have the same problem, or if I go on a bumpy road? Weird
Old Aug 23, 2007 | 07:17 PM
Most likely the resistor pack that regulates the fan speeds is failing, don't run the higher speeds, running a slower speed actually allows the a/c to keep up with the heat and blow colder air.
Old Aug 23, 2007 | 10:21 PM
okdiscoguy's Avatar
Mine does the same thing every now and then. Just touch the switch and it comes back on. Probably in the selector switch. I just haven't torn mine apart yet.
Old Aug 24, 2007 | 07:50 AM
One might think it is the switch, but it is usually always the resistor pack which do burn out especially when you run your a/c in the high position.
Old Aug 24, 2007 | 10:14 AM
okdiscoguy's Avatar
Why would just lightly touching the switch on the dash affect the pack under the dash? I trust your call Mike, just wondering.
Can you just replace the resistors? I haven't looked at the pack yet, but know where it is...
abran
Aug 5, 2014 06:13 PM
AZRover
Jul 2, 2012 06:43 PM
jaxrvr
Apr 24, 2005 12:01 AM
garover
Mar 21, 2005 10:10 PM
flyingcouch
Jan 22, 2005 08:25 AM
