Calling all differential experts...
Old Sep 20, 2021 | 08:20 PM
Boostle's Avatar
Default Calling all differential experts...
https://photos.app.goo.gl/ns1g6QNxE8bteHhg7
is this normal to have that much play with the nut and flange off? I'm trying to trouble shoot a vibration issue at 70 mph and was thinking maybe a bent front diff flange.
Does the nut pull everything together and seat the two conical bearings and shims? Should there be this much play?
Thanks.
Old Sep 21, 2021 | 07:12 AM
frostythor's Avatar
hi I have just done a diff on another car, yes its loose before you put the flange on and tighten the nut, now it needs to have the preload done, with the one I have just done it wa 9-11 in lbs, not a lot it just keeps every thing snug, I had to replace my crush spacer, on the diff, as the old one was 1/8in smaller than the new one so when I tighten up the flang nut it lock the pinion up solid,
so having had aquick look at the manual, it does not show a crush tube it sayes tighten it up to 74 ftlbd
as your pinion uses shims not a crush tube
watch this
homerj
Nov 16, 2018 06:28 PM
mutant
Jul 26, 2017 05:26 PM
dr. mordo
Mar 10, 2013 08:58 AM
ATXDisco
Aug 1, 2011 09:47 PM
ColoDisco
Mar 4, 2011 12:33 PM
