Camel Steel Wheels for D2
Another option would be to buy wider tires. D2 alloys are 8" wide IIRC and you're running 235/85/16's which are fairly narrow. Moving up to a 265/75/16 or 285/75/16 would let your sidewalls stick out past your wheels and take the brunt of the rock rash. But then again you may just end up blowing out sidewalls left and right.
And one last thing to consider. The D1 and D2 alloy wheels hold a bead really well. Steel wheels often won't hold a bead as well as the stock alloy. So if you like driving on the sides of your wheels you may find yourself losing beads with the steel wheels.
16" Army style wheels and tyres, no good on the highways for noise but should last better than your alloy wheels. Bigger taller tires IMO and watch out for the rocks, they bite you and your wallet.
Yeah steel has some advantages, but I agree the double lip on a stock LR Alloy will keep that tire on the bead for sure.
I've got a set of Ebay all metal D2/P38 Lug nuts and I'm very pleased with them. No more loose cap or fighting with sockets anymore!! Best 35.00 I've spent.
Old Florida Road must be a heck of a place to wheel! Those TFs are definitely aluminum, but I've heard pretty good things about the quality. There are some decent choices for aftermarket wheels. Check out one of the best LR parts place (and no, I don't get discounts to say that, they just are pretty awesome)
It was! Watch out for the curbs...
The P38 steel wheels dont look as good as the steel wheels used on Camel Trophy rigs. Ive decided to track down RRC114560MUW wheels instead. Saw them mounted on a Defender, painted white and they do look good so. Thanks for the useful info and part numbers.
The wheels you mention were never used on defenders. You are thinking of wolfs, which look like these but have the opening for the drive member.
craigalmaguer
Mar 21, 2016 02:44 PM
Camtait95
May 26, 2014 09:48 PM
kpl1228
Nov 20, 2010 11:05 PM
