Camshaft end float (Crower 53229)
Yesterday, I got my new Crower 53229 cam installed in the block. I installed the thrust plate and checked the end float. There is approx 1/4" movement in the shaft (a lot more than the original shaft). THe RAVE calls for 0.003 to 0.010".
Is this amount of movement OK?
I have read that some people ran the 50229 (old style) cam without a thrust plate.
Edit:
I may be getting ahead of myself. I just noticed that the RAVE says to measure end float with the gear installed. I did not have the gear installed. The old shaft didn't have a lot of movement without the gear installed and that was cause of my alarm.
While I am waiting for a new gear from Lucky8. I will installed the old gear and check float. I assume the gear and shoulder on the cam will capture the thrust plate, eliminating most of the end float..
Edit:
wizwith
04-30-2010 12:11 PM
