Camshaft and Lifters replacement
Now that I've eliminated the lower deep thud knock, by replacing the main bearings, I want to see what effect changing out the camshaft and lifters will have on the diesel sounding very slight top end tick. I'll check out and replace anything rocker arm related once I'm in there but have one question about the camshaft.
Can I remove the camshaft without removing the radiator? I've measured and it seems close, just wonder if anyone has done this with the engine in the car.
Thanks.
Thanks.
About prices, whats the deal? They are all over the place and differ immensely from website to website?
Does D&D do anything to the Crower Cam other than machine the shoulder to fit in the retaining plate on the Bosch V8? Because if not, is there any harm in just omitting that plate? The new chain will keep everything in line while running. D&D is sort of a tough pill to swallow when they'll only sell you a $500+ cam kit (from what I was told when I did this to my LWB), when you can order the same from Crower directly and pay less than half...
It was not I that found cheaper rocker arm assemblies, but some one posted about like $135 from AllMakes on a direct internet order, not via a regular distributor. You cam exam rockers and shaft without removing valley pan, just 4 bolts. hold the assembly down.
If you are going to change lifters and cam, if mushroomed they may not pull up and out, but instead drop out the bottom once cam is out. You can rubber band them together to hold them while moving cam.
I just bought and installed Alllmakes rocker shafts and arms from Quality Land Rover Parts Spares and Accessories Online ($155 shipped). I paid by Paypal and the receipt said Allmakes, Ltd.
I did not have any problem with them and they did resolve my ticking noise.
Another option for a cam would be a Kent H180: Kent Cams - Product - Camshaft / Camshaft / H180. However you would have to get it form the UK and its expensive £204.00 from Turner Engineering
Here are the specs for the 229. Buick Hydraulic Flat Tappet Camshaft - Camshafts
Turner Engineering states this on their page for the Crower 229: Can be used on engines equiped with cam retaining plate if discarded or machine the cam nose to accept cam retaining plate.
You can get the 229 for a around $155 (Summit, Jegs Amazon)
