Can I Chop it Off?
Old Jun 4, 2020 | 07:43 AM
Ting's Avatar
3rd Gear
Default Can I Chop it Off?
I bought a Disco 1 metal front bumper and with a little bit of a mod, it fitted beautifully to my disco 2 (Import and tax would make a new metal disco 2 bumper around 2k making a 2nd hand disco 1 metal bumper at $100 very appealing). The thing is it came with a winch which will not fit unless I chop off the support under the radiator (see attached). With the metal bumper instead of the plastic I feel that the lateral stiffness of the vehicle has been improved alot but before I get rid of this piece, I thought I would suggest it to the more learned participants of this forum. All input gratefully received.
Old Jun 4, 2020 | 03:47 PM
frostythor's Avatar
Hi Ting
I have just installed a similar bumper on my D2, if you look at that member the question you need to ask is this member I want to remove Structural to the stiffness and rigidity of my chassis,
I think the answer is not its not, so cutting it of will not reduce the strenght of your chassis, an if you check out page 77-1-1 of the RAVE manual, its not shown as part of ther chassis
Old Jun 4, 2020 | 03:49 PM
Extinct's Avatar
Whack it off, did the same on mine with the winch bumper. No issues.
Old Jun 7, 2020 | 09:28 AM
Ting's Avatar
3rd Gear
Thank you very much for your learned advice. Why didn't I think to read the RAVE?! I'll chop it off this afternoon and get back to you if the body falls off!
Old Jun 7, 2020 | 11:12 AM
frostythor's Avatar
Ting, before you cut it off, try and leave a two short section either end so you can refit the Rad plastic cover , other wise you will not have any holes to put the location feet on the Rad cover into
Old Jun 7, 2020 | 11:14 AM
Best4x4's Avatar
Yes when I cut mine for the TF front bumper I left like 6inches on each side. Or when you look at it from the sides you'll see the extra layer of metal under it. I cut it just past that so use that as a guide.
WeekendWarriors87
Aug 29, 2022 09:03 AM
droidbrew
Dec 15, 2017 03:29 PM
SquarePeg/RoundHole
Jul 6, 2016 07:25 PM
bballjames
Feb 11, 2015 02:52 PM
AuZZZie
Dec 11, 2011 02:27 PM
