Can I drive the truck without the front driveshaft installed
My 2003 Discovery II recently got the front driveshaft u-joint broken. I had the front driveshaft removed and sent it to a machine shop. However, the guy messed up the shaft when he tried to press the u-joint out. So now I have to wait for the new driveshaft I just ordered online. I figured the front driveshaft only connects the tranferbox to the front diff. So if I have the front driveshaft disconnected, I should be still able to drive the truck with the rear-drive only. I am not sure if there is any other implications other than not getting the 4-wheel drive?
Can anyone with the experience/expertise on this help me out? Thanks,
Well you could jam a pipe into the front U-joint on the transfer case to lock it.
Bet it would drive on the back diff then.
If the front output from the transfer case is jammed with a pipe, you will get power to the back diff via the transfer case.
Well, the pipe could slap around - but it would work in a pinch to get you home.
![EEK!](https://landroverforums.com/forum/images/smilies/bmHv6Xb.png)
![Confused](https://landroverforums.com/forum/images/smilies/muBAORM.png)
![Big Grin](https://landroverforums.com/forum/images/smilies/lxvR5hR.png)
![Wink](https://landroverforums.com/forum/images/smilies/Uh2vXQr.png)
In all seriousness, I haven't got a CDL on mine and have never missed it and never use the low range either only to exercise it now and then. But I don't do offroading per se so don't need these extras. Got the old trick Pajero for offroading with all 3 diff lockers and a 'magic' transfer box and autobox. Only problem is the motor is old mechanical injection pump techno.
Who LR
.............. never
............... how could they ................. ![Big Grin](https://landroverforums.com/forum/images/smilies/lxvR5hR.png)
![Mad](https://landroverforums.com/forum/images/smilies/MMiQGA5.png)
I was easy on it under accel and whenever the torque converter was locked up at higher speeds, but other than that it actually drove MUCH better.. far less NVH, better mpg, more quiet, etc.
I just found an 06 Jeep Liberty diesel for the GF and it can either be (as is normal) 2WD (RWD) OR full time AWD also..
Oh you can also lock it into part time AWD AND AWD / low range.
bcolins
02-09-2014 08:35 PM
TripleThreat
04-12-2011 08:58 AM
