Can I put 245/75/16s on a stock alloy 8 inch wheel?
Old Feb 20, 2013 | 06:49 PM
KlamathMatt's Avatar
Default Can I put 245/75/16s on a stock alloy 8 inch wheel?
I've learned more about tires in the last few days on this forum than I would have thought possible. But I am still stumped by one matter:
I have a 2000 disco (no lift) with 18 inch wheels that I want to replace. I got a good deal on stock alloy wheels from one source though I have not gone thru with the sale yet. From another source, I have a good deal on some tires in the size I want: 245/75/16s from another source. Will these fit on an 8" or do I need to go with a 7"l?
Thank you so much for any light that you can shed on this subject!
Matt
Old Feb 20, 2013 | 07:11 PM
dr. mordo's Avatar
I think typically 245 is a bit too small for an 8" rim. I've read the max rim width for 245 is 7.5".
You could use 255/70r16, which is about the same height as a 245/75 but a tiny bit wider.
Old Feb 20, 2013 | 07:38 PM
ZGPhoto's Avatar
Go to the tire's manufacturer's website and check for that tire. BFG has all that info on their site.
Old Feb 21, 2013 | 04:33 AM
NickAdams's Avatar
The source I checked before I put them on my truck listed 8" as the maximum width for 245/75/16 tires. It is the size that the previous owner had installed on the 8 inch wide wheels as well. I'm happy with my results.
Old Feb 21, 2013 | 07:31 AM
Big Jim Swade's Avatar
They will work fine on a 8" wheel.
Old Feb 22, 2013 | 09:10 PM
ZB-30's Avatar
I have 245/75's on my 8" 16's, no problem.
dcarr1971
Feb 8, 2013 08:16 AM
peredero
Jun 8, 2010 05:07 PM
Shaymer
Apr 28, 2008 06:56 PM
Shaymer
Apr 22, 2008 12:45 PM
