Can some one please help me make sense of the wiring!
I have got all the issues related to my head gasket cleaned up and the only thing remaining is a P0130 code. the connector from the harness was pretty smashed up so I got a replacement. Clearly I have done something wrong as the code indicates the O2 or the wiring has a short in it. As well know know, two wires are merged in shielding and then split back out into the respective pins. The merged wires have tinfoil sheathing between the merged wires and the outer covering which I tried to replicate. that may be the problem. The other problem is that the wire colors do not match what the RAVE electrical diagram says. Anybody peel further back into the harness to figure out the colors?
Thanks!
Thanks!
