Can you clean water stains from the headliner?
Old Nov 17, 2023 | 03:43 PM
hamitchell62's Avatar
5th Gear
Default Can you clean water stains from the headliner?
How can this be done, if doable?
Thanks.
Old Nov 17, 2023 | 04:00 PM
keninnc's Avatar
Carpet cleaner has worked for me
Old Nov 17, 2023 | 04:10 PM
5th Gear
Great idea. Thanks!
Old Nov 17, 2023 | 07:04 PM
nathanb's Avatar
Pressure washer. Use the carpet cleaner or simple green or whatever and then a high pressure rotary nozzle with low volume of water. A short gun makes it a lot easier inside the car. Blast the water off with compressed air gun and use a shop vacuum to collect the water, but avoid sucking directly on the headliner. Blow the water off the headliner, and catch the water with the vacuum. This works great on automotive carpets too, except that there is no issue sucking it up with the vacuum in that case. You'll want to be prepared to get any water that gets under the carpet, which can be a lot of work, so be careful near the edges. I live in an arid climate so everything is dry the same day if I do it in the summer.
If you need replacement headliner fabric, check out https://www.ardmore-design.com/collections/fabrics
redwhitekat
Jun 19, 2021 09:57 PM
mr. choodles
Feb 13, 2018 11:20 AM
jdelp
Jul 13, 2008 11:40 AM
discoguy
Jun 22, 2008 04:00 PM
johnnybob06
Jul 18, 2007 12:16 PM
