Can you recommend a High Power alternator for Hella Lights?
6 100w bulbs = 600w = ~50a @ 12vdc.
If you're not running the A/C, heated glass, bun warmers, and other high-draw stuff you'll be fine with the lights even at low RPM (alternators are not rated at idle).
Regardless of the size of your battery/batteries, you need to have enough charging to be able to carry all normal loads (not necessarily intermittent, like starter and winch) plus a little left over for charging or you will deplete the batteries.
More to the point will your battery and overall wiring system stand the extra power requirements. Lights are a major power soak if they aren't LED's. The alternator charges the battery and tops it up and everything operates from the battery therefore the alternator merely ensures the battery is as fully charged as possible. More draw requires more storage or in other words a larger capacity battery. You can buy larger capacity batteries and alternators bearing in mind the more power you draw the heavier the fuel consumption when drawing down the additional power. The analogy is a portable generator, when there's no load power drawdown the engine ticks over comfortably when it's on max power drawdown the engine works far harder using more fuel and indeed sounds like it is working hard.
pdcrawford
03-23-2014 10:49 AM
StartupRacing
02-14-2006 06:12 PM
BridgeRover
02-14-2006 01:14 PM
