Can you run a test for me?
Old Jul 25, 2013 | 03:24 PM
caymandrew's Avatar
Default Can you run a test for me?
Guys, I need the help of another fellow land rover enthusiast, I need a definitive answer to a question and do not have another Disco 2 laying around to test with
The idea is that once you remove the spark plug wire from cylinder 1 or the adjacent cylinder 2, you should hear a knock as the opposing force is now gone. Or cylinder 5 and 6. Look at this video:
If anyone could try this I would be very greatful. It's the only way for me to know if I have a problem or this is normal behavior.
(FYI, in my other rod bearing threads, this was the knock I was chasing, which is now gone while engine hot and at idle. It only comes back if I unplug some of the wires so I need to know if it's normal.)
Old Jul 25, 2013 | 11:57 PM
jfall's Avatar
OK so all I can think of..
The cylinder has the wire pulled.
IT goes into compression as normal.
Gets a fuel charge from the injector.
Wire is pulled.
So, compressed gas in cylinder just uncompresses with out a power stroke.
not sure how this would cause an imbalance.
The video though does tell it all.
film842
May 1, 2015 10:28 AM
m3dragon
Feb 24, 2015 10:08 AM
wisconsinoverlander
Apr 26, 2012 10:24 AM
calebbo
Oct 12, 2011 09:54 PM
kschintz
Off Topic
Oct 4, 2007 12:09 PM
