Cannot find coolant drip source...
Can you give me some clues, please ?
Coolant drips about once a minute to the top of the differential pumpkin. From underneath, this old belly and eyes cannot determine where is it coming from. Somewhere under behind the alternator is as far as I can trace it, coming down the front-right of the block. Seems not coolant pump related, but could be wrong. With good light between the compressor and alternator, there is no puddle in what seems to be the valley pan.
Suggestion: Do not get old, it's the ****s. What used to be a 5 minute task becomes hours... when dare to tackle it.
Thanks.
A pressure tester would tell me the same I see with residual pressure after parking. What I need to do is remove the alternator hunting for the source, but I need 20 years less to motivate, and a better weather...
Everything looks dry from above and around the pump, tbh nipple, temp sensor, valley. Is the heater core nipple at that location behind-under the alternator ?
Removed the alternator, found the port that supplies the heater core, circled with red, bone dry. No signs of leaks anywhere in the area.
In another session I would have to remove this belt tensioner and alternator support :
Pictures borrowed from the web :
The drip appears to come from between this pictured bracket and the head front face. Have no idea what may be leaking behind it Suggestions welcome.
How about this area? This is the pipe that brings coolant out of the engine to the rad.
If not, the only other possibilities in that area are the water pump to TC cover gasket, TC cover to block gasket, or the head gasket. Removing that alternator/tensioner bracket is not tough and should give you a good view.
