Cannot find coolant drip source...
Old Dec 24, 2019 | 10:30 AM
Externet's Avatar
Question Cannot find coolant drip source...
Can you give me some clues, please ?
Coolant drips about once a minute to the top of the differential pumpkin. From underneath, this old belly and eyes cannot determine where is it coming from. Somewhere under behind the alternator is as far as I can trace it, coming down the front-right of the block. Seems not coolant pump related, but could be wrong. With good light between the compressor and alternator, there is no puddle in what seems to be the valley pan.
Suggestion: Do not get old, it's the ****s. What used to be a 5 minute task becomes hours... when dare to tackle it.
Old Dec 24, 2019 | 10:38 AM
mln01's Avatar
Have you "rented " a pressure tester from an auto parts store?
Old Dec 24, 2019 | 11:36 AM
Best4x4's Avatar
Temp sensor hole, nipple on intake to TBH or coolant reservoir (if TBH is bypassed), maybe the water pump weep hole & it’s being blown back, or front timing cover gasket at the water pump area, upper valley gasket.
Old Dec 24, 2019 | 11:57 AM
Externet's Avatar
Thanks.
A pressure tester would tell me the same I see with residual pressure after parking. What I need to do is remove the alternator hunting for the source, but I need 20 years less to motivate, and a better weather...
Everything looks dry from above and around the pump, tbh nipple, temp sensor, valley. Is the heater core nipple at that location behind-under the alternator ?
Old Dec 24, 2019 | 01:22 PM
Best4x4's Avatar
The nipple is a bit lower for the heater hose (at the plastic Y connection) but it could blow up on the front of the engine for sure.
Old Dec 25, 2019 | 07:42 AM
zuke's Avatar
Keep in mind that your fan is blowing any drips to the rear.
Old Dec 26, 2019 | 11:06 AM
Externet's Avatar
Removed the alternator, found the port that supplies the heater core, circled with red, bone dry. No signs of leaks anywhere in the area.
In another session I would have to remove this belt tensioner and alternator support :
Pictures borrowed from the web :
The drip appears to come from between this pictured bracket and the head front face. Have no idea what may be leaking behind it Suggestions welcome.
Old Dec 26, 2019 | 12:10 PM
Red5's Avatar
How about this area? This is the pipe that brings coolant out of the engine to the rad.
If not, the only other possibilities in that area are the water pump to TC cover gasket, TC cover to block gasket, or the head gasket. Removing that alternator/tensioner bracket is not tough and should give you a good view.
Old Dec 27, 2019 | 01:51 AM
shanechevelle's Avatar
On the top of the I take there is a small coolant hose pointing up.
My hose blew off of that and I couldnt find the leak right away.
NWROVERS
Apr 5, 2014 03:06 PM
nuclearw
Aug 11, 2013 04:27 PM
larson3000
Mar 23, 2010 06:19 PM
BajaXJ92
Feb 5, 2010 08:10 PM
lipadj46
Sep 11, 2009 04:59 AM
