Can't find this in the Rave manual
Old May 25, 2014 | 06:14 PM
gundog's Avatar
Default Can't find this in the Rave manual
I have the truck apart replacing a power steering pump and I noticed an odd part that I could not find in the Rave manual diagrams. It is a cone shaped ring that sits behind the crankshaft pulley and it is loose (see picture, the end of the screwdriver is pointing to it. I recall several months ago I started hearing a clanging noise and thought it might be a loose timing chain. Now I am thinking that this might be the cause. Anyone know what this is? I don't think it is part of the seal. Thanks for the holiday help.
Old May 25, 2014 | 06:24 PM
OffroadFrance's Avatar
Looks like a thrower/protection plate (similar to an internal oil thrower) of some kind, probably to protect the crank oil seal from grit and debris.
Old May 25, 2014 | 07:23 PM
Jared9220's Avatar
I believe that piece is part of the crankshaft pulley/harmonic damper. If it is loose then your crankshaft pulley might not be on tight or your pulley might be going bad. It needs to be tightened to 200lbf.ft. Have you removed the timing over recently?
Crankshaft Pulley / Harmonic Damper (Genuine Part # LHG000060 ) - Land Rover ancillary components from Atlantic British
Old May 25, 2014 | 08:45 PM
Good one Jared9220, well intervened.
Old May 25, 2014 | 08:52 PM
Jared9220's Avatar
Start the truck and crawl underneath and look at the Crank pulley. Is it wobbling really bad?
Old May 25, 2014 | 11:44 PM
jfall's Avatar
air wrench and large socket
make sure the hb is in the key and the key is in the keyway
msm15
Jun 29, 2011 02:19 PM
Aj6543
Oct 1, 2008 05:37 PM
unstable
Apr 29, 2008 07:44 PM
