can't get air filter box off
Old May 23, 2013 | 04:58 AM
a-rod's Avatar
Default can't get air filter box off
Maybe I am crazy but I can't seem to get the air filter box to come out on my 2000 disco 2,
I have un clipped everything and disconnected maf, 2 of the clips come out but the third doesn't seem to want to cooperate, everything I have read said that it should pop out when you pull up on it
Old May 23, 2013 | 08:06 AM
It does not want to come out and make it easy for you to put one of those worthless conehead rag air filters in.....
Old May 23, 2013 | 08:35 AM
Charlie_V's Avatar
It will come off, but you have to be sure all of the clips are disengaged... there are clips on all sides.
Old May 23, 2013 | 08:47 AM
Mojigglins's Avatar
And give it a good yank.
Old May 23, 2013 | 02:47 PM
a-rod's Avatar
Lol, no. I'm replacing the radiator and I want to take the whole box out so I can get to everything easier
Old May 23, 2013 | 04:04 PM
Be real careful with radiator nipple connection, fragile by nature. And that screw that goes into the side tank - careful with that also.
Old May 23, 2013 | 05:23 PM
SSL9000J's Avatar
Don't know about the D2, but the D1 has two or three little rubber teats on the bottom of the box which hold it to the wheel well. You can see them poking through from underneath. Squeezing them with pliers might help.
Old May 23, 2013 | 06:30 PM
Mojigglins's Avatar
I had to pull on mine really hard, while wiggling in really good as well. and I am talking about the air box lol.
Old May 23, 2013 | 11:29 PM
CANAMDiscovery's Avatar
Search "air cleaner box removal"...
I snapped some photos after removing mine.
Old May 24, 2013 | 04:20 PM
a-rod's Avatar
Thanks man, I replaced the water pump and radiator yesterday, I'll post some pics early this morning when I get off work
