cant get difflock
Old Dec 29, 2007 | 10:04 AM
johng3165's Avatar
3rd Gear
Default cant get difflock
hi has anyone else had the problem of not being able to engage difflock from within the car I can get hi-low box easily with the levelbut can only select difflock from underneath the car by moving the linkage its a disco 300tdi anyhelp would be grateful as would love to go offroad but canttill this is sorted
Old Dec 29, 2007 | 12:52 PM
Adz's Avatar
Adz
Default RE: cant get difflock
Sounds like the lever is disconnected from the linkage, or the linkage is a bit siezed - 10 mins with a torch under the car and an assistant to wiggle the stick should sort it out.
Cheers,
Old Dec 29, 2007 | 01:23 PM
johng3165's Avatar
3rd Gear
thanks give it a try when weather is a bit warmer
Old Dec 29, 2007 | 02:14 PM
Sounds like your t/case solenoid has failed which will not let you engage low range. Can you engage regular low, not low lock?
Old Dec 29, 2007 | 04:39 PM
Adz's Avatar
Adz
Aren't the manual gearbox disco1's a mechanical linkage Mike? Rare for a Tdi in the UK to be an auto - I stand to be corrected though as virtually all my knowledge is Defender biased not discovery (not that there's a huge difference under the skin for a Disco1).
Cheers,
Old Dec 29, 2007 | 06:21 PM
You still will have a switch on the tranny and a solenoid on the top of the t/case. If that solenoid doesn't get a signal from the tranny showing it is in neutral, you won't be able to go into low range, has nothing to do with the t/case linkage.
Old Dec 30, 2007 | 03:28 PM
Adz's Avatar
Adz
I disagree Mike - I can't find a single reference to a solenoid in a manual gearbox or that the manual box needs to be in neutral to change between hi and low on the T box and certainly not to engage difflock on a Disco 1, you can do that on the fly while still moving and in gear. That's the R380 gearbox for a 300 Tdi, not the ZF auto you'd find on a NAS V8.
Old Dec 31, 2007 | 07:54 AM
johng3165's Avatar
3rd Gear
hi thanks for your answers its a tdi manual box canselect hi an low ratios ok via the level from inside, but cant get the difflock from inside have to get underneath and move linkage with a pry bar. where can i find this t/case solenoid and is it easy to remove
skezixx
Oct 24, 2011 09:56 AM
greg409
Aug 4, 2010 08:05 PM
bradbenz
Oct 24, 2009 08:53 AM
03discoman
Sep 2, 2009 11:44 PM
Bene
Aug 30, 2005 09:39 PM
