Cant get rid of engine tick on new motor!!
Old Sep 1, 2009 | 08:05 PM
03discoman's Avatar
Default Cant get rid of engine tick on new motor!!
I have a 2003 D2 with 125k
i've had the engine rebuilt because of a sound that i cant seem to figure out.
its deffinatly a tick or upper valvetrain sound. i think its due to oil pressure . when the car is cold i have no sound when it warms up... i get the sound. i can deffinatly hear it more on the passenger side front lifter area i have a new oil pump/timing cover i'm running 20w50 with lucas. and i'm using a m204 mobil 1 filter.
roller rocker shafts are new as are pushrods, lifters and timing chain.
i reused the old cam and cam bearings because my engine guy said they were fine.
motor drives great on throttle and i only get the sound at idle to 1500 rpm.
can a converter do that, make that kind of sound?
also i was having oil pressure issues 8psi at hot 2k rpm
i was hoping installing to new oil pump would take care of that.
anyone have ideas on oil pressure or what can cause the noise
Old Sep 1, 2009 | 08:15 PM
Yes a bad cat can cause that sound.
Did you use new rocker arms?
Old Sep 1, 2009 | 08:45 PM
03discoman's Avatar
yes i did
Old Sep 1, 2009 | 08:46 PM
Hmmm...I need to think about this one.
Old Sep 1, 2009 | 09:51 PM
malmberg's Avatar
I have that same tick that you described. I can only hear it untill around 1500 rpms. I bought my disco with about 60k miles on it and it had the slight tick. At around 100k I had the headgaskets done, lifters, and a couple of rocker arms that the mechanic said looked bad. After picking it up from the mechanic I noticed that the damn tick is still there. It is only noticeable when the windows are down with something next to me or outside it. I hate the noise but I figure that I am just going to have to deal with it untill I have to rip the motor apart again. Next time I will replace the cam along with all of the rockers but I still don't know if that will even fix it. Most discos that I have seen seem to have a slight tick. We should start a poll to see who has it and who doesn't. Maybe it will help you to know that others are in the same boat with you.
Old Sep 1, 2009 | 09:59 PM
lipadj46's Avatar
I used to until I did my head gaskets and cleaned everything out and switched to 15W-50 mobil 1. I did not rebuild anything. No idea what it was caused by but it sounded like a diesel engine. Sounds like a normal V8 now.
Old Sep 2, 2009 | 09:11 PM
xengineguy's Avatar
Whats your oil prssure now? If its still 8psi @ 2000 I would look at the pressure release in the front cover....Easy to remove and clean..
remove the snap ring,use a large punch and tap on the solid plug until it slides out, an o ring holds it sometimes... Its spring loaded so it might come out with out any tapping needed. Clean everything,lube with cam lube/eos or whatever. Try it.. I bet you he find a broken spring or just mucked up....Test the pressure before and after.
Old Sep 2, 2009 | 09:47 PM
demonlarry's Avatar
are you sure its not just the slightest exhaust leak?
Old Sep 2, 2009 | 11:44 PM
03discoman's Avatar
front cover is new as is the oil pump.... exhaust is new also all the bolts and exhaust gaskets... including flange bolts.
i think my mechanic should have replaced the cam bearings when he had the chance!!!!
i dont know my oil pressure because my oil guage doesnt have the proper fitting to tap into the sending units threads
xengineguy
Nov 12, 2015 12:23 PM
XCELLER8
Sep 19, 2009 03:27 PM
zracin
Mar 7, 2008 01:17 PM
Kraftyz51
Aug 19, 2007 03:58 PM
97XD
Feb 2, 2007 07:46 PM
