Can't locate mild vibration!
I gave you the example of the X5 because it's just the most recent. It was a friends and he was 100% sure wheel bearing. Not so much. But I've had this happen with LR brakes(of all years) many times. Last month a friend replaced a rotoflex (proper GKN) and the U joint in a DI... still had a vibration. Drove him mental, and it was the left rear caliper inner piston that was stuck. R&R'd the caliper, rotor, and pads and problem solved.
Is the solution always the brakes/claipers.....NO. It's just one good/easy place to start the elimination. Post a pic if you need to get some opinions of what you are looking at. GTG... you'll get it sorted, Good Luck!
I have just Googled the vibes problem. It appears a common D2 issue, there are pages and pages of potential causes in multiple forums it would appear and no-one seems to have resolved this problem satisfactorily. Many have spent fortunes on balancing, tracking, tires, tire pressures, driveshafts, wheel bearings etc, etc including Panhard and steering shock bushes and invariably without any success. It seems a complete mystery as to the causes of the dreaded vibes in most, if not all, cases. I think that maybe Landrover UK itself is the only final resolution to this mystery. I'll try writing an e-mail to them, but don't hold your breath as they aren't renowned for their helpfulness.
Alright, I just experienced a very odd phenomena.
Backing out of my driveway to leave for work, I bumped the curb on the other side of the street. Just hard enough to kindof make my head bob against the head rest,
The next mile of driving to the gas station was the smoothest mile I've ever felt in this disco. Little to no vibration at all, at any speed (only hit about 50).
But, as soon as I hopped back in and left the gas station, vibration was back to normal. Wtf is going on?
Had a vibration on my wife's 03 that was driving me crazy, would come and go at first, but finally stuck around for good. Ended up being the right rear caliper. I'd done the brakes not long before it appeared, and all calipers pushed in smoothly...so I keep looking in different areas. Had it jacked up to check rear hubs (which didn't seem lIke the issue solver)...and couldn't turn the wheel. New caliper solved the issue.
You may have hit the curb hard enough that it flexed the rotor, pushing the caliper cup in temporarily.
Brian.
Brian.
well i know what im doing tonight after Krav Maga, gettin this black POS up in the air and checkin out the brakes lol. thanks yal, will report back with my findings.
btw, can i pinch the brake line and pull the pistons out of the calipers, for the purposes of resurfacing them? or am i in danger of damaging the seal in the process?
i ask because i would like to avoid buying calipers if a DIY fix is a possibility.
Thanks to all you guys, I've lived with the vibes for a couple of years now and it may be sorted with your help. Fortunately I have a completely new set of original equipment for all 4# corners to install, calipers, carriers, rotors, s/s hoses and pads. Looks like I'm gonna be busy
Everything except the rotors and pads are original whereas the Bearmach rotors are drilled and grooved.
Back to the drawing board fellas, brakes are in fantastic shape. Greased the pins and pad plates for good measure but everything is wearing strait and even. Rear rotors and all pads look basically new.
are the rear output yoke nuts known for loosening up like the fronts? My rear shaft on the transfer case side did appear to have a slight wobble to it. I started it up and put it in gear too check for any oddities and that's the only think I could see that might be out of wack.
