Can't read 3 amigos codes
Old Sep 13, 2012 | 08:47 PM
nate2k5's Avatar
Default Can't read 3 amigos codes
So I am having a frustrating issue with my disco. When I bought it the lights were not on but came on about every other time I drove it. I was able to read the codes initially with our euro version Launch but the lights came back and I haven't been able to check them since. It says no codes. A while ago I believe I pulled the ABS fuse while the vehicle was running and the 3 amigos plus the brake light are on all the time and i still cannot check the codes. aby ideas?
Old Sep 13, 2012 | 09:38 PM
ebg18t's Avatar
Most generic code readers cannot read brake related codes.
Old Sep 13, 2012 | 10:21 PM
nate2k5's Avatar
it is not a generic code reader.
http://www.ntxtools.com/network-tool...301100363.html
Old Sep 14, 2012 | 09:40 AM
Find someone with a 3 Amigo scanner or buy one for $200 and it will help you read, repair and clear the codes.
Old Sep 14, 2012 | 09:44 AM
coors's Avatar
Or go to the dealer. They're basically your only two options.
Old Sep 14, 2012 | 10:30 AM
nate2k5's Avatar
it is not a scanner issue i do not believe, it has the SLABS diagnostic tool that worked before. i think the issue is that the code clears after you turn off the key.
Old Sep 14, 2012 | 01:41 PM
nacircle's Avatar
I am considering investing in a good scanner for my discovery II. I have a ultragauge for my coolant temperature. I wonder what is a good or recommended scanner for discovery II
Old Sep 14, 2012 | 01:50 PM
Bkreutz's Avatar
Depends on what you want to use it for. the price range is $50 to $20,000. Your ultragauge will read all the OBDII codes, what it will not do is read SRS, ABS, or allow you to personalize various settings or calibrate engine, transmission or suspension ECUs. The more expensive tools will also access the Body controls so you can activate various accessories and check functions of the systems (lots easier than replacing parts). All depends on you budget and what you want to use it for.
SuperSport
Oct 14, 2013 11:03 AM
jfall
Jan 20, 2013 10:24 PM
s10lowrider1994
Jan 25, 2012 04:29 AM
krazzz
Sep 1, 2009 10:38 PM
benflynn
Aug 19, 2008 08:20 PM
