capless lugnuts for alloy wheels
Old Apr 11, 2025 | 09:04 AM
Alex_M's Avatar
Originally Posted by WaltNYC
another method to remove SS caps...
https://youtu.be/bqW9eobZ5Fw?si=sZvZVfTMeHOvjhD7
This works, or you can vice up the lug nut on the round that recesses into the wheel and use a socket extension and a hammer to remove the cap. Saves a trip to the hardware store to get a bolt. Pictured here. I write in the post to use a 1/2" drive extension, but I believe it is actually a 3/8 extension that I used.
Old Apr 11, 2025 | 07:05 PM
disco96sd's Avatar
The Dorman parts are open ended
Old Apr 12, 2025 | 07:44 AM
jimvw57's Avatar
The Discovery 2 uses a different size lug nut and won't interchange with Discovery 1 or classic Range Rovers
Old Apr 12, 2025 | 09:40 AM
Harvlr's Avatar
But are the same as the P38
Old Apr 12, 2025 | 05:24 PM
jastutte's Avatar
Originally Posted by Alex_M
Those dorman lug nuts will not work with factory wheels. The wheels do not take an acorn style lug nut; they take a flat seat style lug nut.
****. i think you're right. they do take an acorn style but it has to have the flat seat, as well.
Old Apr 12, 2025 | 05:25 PM
jastutte's Avatar
the one's i purchased are not open ended. but, won't work anyway due to not having a flat shoulder.
acg
May 10, 2021 10:43 AM
emtuzas
Oct 22, 2018 06:20 PM
dcarr1971
Feb 8, 2013 08:16 AM
DonRW2007
May 12, 2012 10:14 PM
