Car leans to the left....
First off - I weigh 205# and the car leans to the left (drivers side) and I am pretty sure it is not me!!!
I bought the car like this and thought it was:
A) underinflated tires
B) maybe the car would reset itself and all would be good
C) the shocks/struts were bad on the front and back.
Well, I checked the tires - so A) is out of the question and B) doesn't seem to be happening soon so I am thinkin either C) or
D) the airbags are not inflated/inflating properly.
So in short - I have no freakin' idea whats going on - but there is a noticable lean that you would notice if you stare long enough...
Do you have SLS (air bags in the rear) instead of springs? If so, does it lean when the engine is turned off, or also when running? My SLS Disco2 always leaned when off, but OK when running, and dealers said this is OK and did nothing. If it always leans, then you might try to adjust the self leveling sensors at the rear. And just what it is the height difference, in inches? I figure a 2 degree tilt is about 1.75", which is alot. (If you don't have SLS then never mind)
I will have to check when I pull the rear tire off. I have been VERY intimate with the front half of the Rover ever since I pulled the engine last month - but never really played with the back half.
The car seems to lean whether it is on or off. I don't here the air bags adjusting itself too much - I hear a quick 'burst' or 'phist' and that is it....
Anyway, x2 on broken or saggy springs.
